understanding codes?
can any one make light of these codes pulled from the climate control
04.1
Value supplied by Temp. Sensor is used if sensor fails
05.1
06.1
Engine Coolant Temperature is calculated is sensor should fail or is not installed; diagnosis occurs only above 0 degrees Celsius---- i is cold out tonight probly right around 32f so i dont know if that has anything to do with it
*07.1
Programmed corrective value = 0
08.1
Temperature Regulator Flap Motor will no longer be controlled automatically; manual adjustment only
*11.1
Central Flap Motor will no longer be controlled automatically; manual adjustment only
15.1
Digital value is internally programmed for limp-home modealot of the codes say the same thing? also my temp. dose not diplay in the gauge cluster could it have been truned off somehow is there a way to ture it back on in their? any input would be great also i had alot off 255 come up
04.1
05.1
06.1
*07.1
08.1
*11.1
15.1
