Understeer? HA!
Old Sep 27, 2007 | 01:49 AM
  #41
sdboarder84's Avatar
Default RE: Understeer? HA!
hahahhaaha how do I make my audi handle like this!!!!!!!!!!! i wish.
http://www.youtube.com/watch?v=hMSBNm4mmQs
not put doen good driving but if you to learn how to use your ebrake you can turn just like him, watch the back tire when you get the inside view of him making that gnarly hairpin. The proper word for them actually are are cutting/ turning brakes, they will lock up which wheel you choose, they are very common on rally cars and sand rails. Yes I know he is a good driver and has a ton of suspension work. Not putting it or his driving down just pointing somehting I am sure most people missed.
Old Sep 27, 2007 | 04:48 AM
  #42
Belligerenceā„¢'s Avatar
ORIGINAL: cincyTT
ORIGINAL: Noobinator
All new suspension, 30/70 power split, FAR better brakes and tires and you should be able to do something like that. But not in your fat wagon
not to mention you're going to need to roughly triple your horsepower.
Old Sep 27, 2007 | 09:36 AM
  #43
kextyn's Avatar
ORIGINAL: cincyTT
Think its constant 50/50 and the Haldex TT's constantly change from 90/10 to 50/50. Evos run like 40/60 and sti's can switch from 50/50 to either 30/70 or 40/60
It's only 1:1 if there is no difference between front and rear (no slip), but it can go up to 2:1 I believe. You can get a new Torsen center diff with a 7:1 ratio from Stasis. It's really not that bad of a price I think for the difference it makes in handling. ($550, but also a 550 core charge).
To make it simpler to understand. 1:1=50/50, 2:1=~66/33 (I think the stock Torsen is supposed to be 60/40), and 7:1=88/12.
Old Sep 27, 2007 | 10:01 AM
  #44
kextyn's Avatar
Cyber, that picture in your sig...is that with the sway bar or without? That's a lot of body roll already and if you remove the sway bar you're going to be getting more. To me that's way too much body roll in that picture and without the sway bar you're probably going to lose traction as well and probably lift the inside tire. It may be fun but I would only do it for autocrossing or something and NOT on the street or a full track.
Old Sep 27, 2007 | 10:20 AM
  #45
acetrebo's Avatar
Ok,
why do you think it behaves this way?
My best guess is removing the sway, causes more body roll to the outside tire, putting more weight onto that outside tire, causing it to grip better than before.
Can you notice more body roll? Any other handling changes noticeable?
Could there be any negative effects from doing this, increased tire wear, more wear on the suspension, etc.......
It sounds like it might be worth a try, the car does understeer horribly. (at least if you are going fast enough!)
Old Sep 27, 2007 | 08:12 PM
  #46
CLX's Avatar
CLX
Zombie Defense Force
OMFG wheelhop!
And in the sig, that's totally with the front sway bar on!
Joe Edgerton
Aug 22, 2012 03:54 AM
peep
Jul 8, 2010 05:24 AM
kolan67
Sep 18, 2007 08:51 AM
bzalforno
Sep 30, 2005 07:17 PM
cgv988
Aug 22, 2005 04:50 AM
