Uneven Pad Wear
Old Dec 9, 2006 | 05:49 PM
duburban's Avatar
Default Uneven Pad Wear
I just did my pads and rotors all around. My right rear pad isn't wearing on the whole rotor. Only the upper half is getting rubbed by the pad. I pulled my e-brake a little to try and seat it, i did notice that it did rub some of the bottom half too. Anyone experienced this? Am I looking at a new caliper? Thanks
~Dave
Old Dec 9, 2006 | 06:12 PM
outasflyguy's Avatar
Default RE: Uneven Pad Wear
er um i have a similar problem... just changed all the pads on each wheel and theyre squeeling like crazy. Im not sure what went wrong.[:@]
Old Dec 9, 2006 | 06:31 PM
onepoint8tee's Avatar
ORIGINAL: outasflyguy
How is your squeeling similar to uneven pad wear??
Anyway..
If your rotors were warped at all, that can cause uneven pad wear, so can a caliper not functioning properly. Keep an eye on the new set of pads/rotors. Take the wheel off in a couple months and see how they are wearing.
Old Dec 9, 2006 | 06:37 PM
similar in fashion of the topic being brakes??? lol
Old Dec 9, 2006 | 06:54 PM
wood_e's Avatar
Check your slider pins too.
Old Dec 10, 2006 | 04:14 AM
duburban's Avatar
good call on the slider pins. the pads and rotors are completely new all around. this is the only wheel thats wearing strange. So the caliper isn't very suspect? haynes manual said to replace slider pins at every pad interval, i didn't.
Old Dec 10, 2006 | 05:03 AM
wood_e's Avatar
You don't need to replace them. Re grease them and make sure they move well.
Old Dec 10, 2006 | 07:51 AM
luvin_the_rings's Avatar
they sell non-squeak stuff that you spray on the back of your pads that makes it stop squeaking...
i took out my stock pads and sprayed that stuff on and there is no more squeak... look into it...
Old Dec 10, 2006 | 03:39 PM
acetrebo's Avatar
Any high temp silicone (like high temp gasket sealer/maker) will work. Just put it on the backside of the pads and re-install.
Old Dec 10, 2006 | 03:50 PM
techbod's Avatar
you call it copper grease I call it copper slip
http://images.google.co.uk/images?q=...m=10&hl=en&lr=
I would say a break caliper service and check the break pistons for sticking
