unknown fluid??????? help
Old Dec 2, 2007 | 01:39 PM
dubblrest1985's Avatar
Default unknown fluid??????? help
last night we got like 4-6 inches of snow!! ha my first snowfall with my 3.0 quattro 6 spd and ha its real fun, but any ways i was the only person to pull in and out of my driveway this morning just once, and as i was walking back to my house i noticed a trail of green fluid spots up my driveway right to my car, so im like WTF????? antifreeze? then i got to thinkin that the antifreeze has a reddish tint to it cause its different than the domestic fluid i normally used, any ways i checked to see what fluids would be green and i didnt see any? washer fluid is blue coolant is red hydrolic is brownish and obviously its not the oil... what else would it be? am i right that the antifreeze/coolant is redish? any info would be much appreciated!!! and i know that i was the only car to be up and down my driveway this morning....
Old Dec 2, 2007 | 01:56 PM
onepoint8tee's Avatar
Default RE: unknown fluid??????? help
ORIGINAL: dubblrest1985
Didnt you look at the coolant tank? It should be pink.
Old Dec 2, 2007 | 02:00 PM
yeah i did look down into it and it was redish/pinkish but i figured id ask anyways haha
Old Dec 2, 2007 | 02:02 PM
Well, the engine mounts are liquid filled. That is one possibility, but not sure what color the fluid is.Im not sure, but Ithought that oem Audi mineral/hydrolic fluidIS greenish? Might be wrong on that... Another possibility is AC compressor oil. Best thing to do is drop the belly pan and have a look.
Old Dec 2, 2007 | 02:06 PM
well i pulled thecap/dipstick for the hydrolic fluid and spattered it into the snow and its a brown color...
Old Dec 2, 2007 | 02:07 PM
CAB509's Avatar
6th Gear
Look at your power steering fluid, that stuff is green. (well it should be)
Old Dec 2, 2007 | 02:11 PM
okay... its an 03 a4 6 spd with 40000 miles on it, i havent really noticed it any more either, if it is the power steering what do you think it might be? hose pump etc...
Old Dec 2, 2007 | 02:19 PM
CAB509's Avatar
6th Gear
I think it might just be a small leak or something, but i depends on how much fluid leaked out. I'd check the tank and then you can go from there. See how much, if any that you are down. But common areas where it might leak are the hoses at the bottom of the tank, and if you follow them you'll find some more areas where it might leak. I don't think it would be the pump because you'd probably lose a lot of fluid and I know that it isn't the steering rack because then you'd have no fluid and be replacing it every other day.
Old Dec 2, 2007 | 02:20 PM
Make sure the cap is tightly screwed onto your mountain dew bottlenext time.
Old Dec 2, 2007 | 02:35 PM
haha... i dont drink the stuff, another newbie question.. where the f?@# is the power steering resevoir located?
