update, problem solved
Old Sep 24, 2007 | 07:04 PM
turbo kraut's Avatar
Tech Guru
Default update, problem solved
and now i have a flashing check engine light, w/ multiple misfires........ got 2 new coils and it is still doing the same thing....... could it be plugs and not coils? what could be going on?
this is on an 01 1.8t
i fixed it, it was a stupid coil....... i was mistaking cyl 1 for #4
Old Sep 24, 2007 | 07:07 PM
onepoint8tee's Avatar
Default RE: seaformed
Yeah the plugs get wet when you do the intake manifold application. You got new coils because of this? rofl
If youre still missing after the seafoam has burned off you put in too much too quick and soaked the plugs. Its a good idea to put in new plugs after seafoaming anyways.
Old Sep 24, 2007 | 07:09 PM
Tech Guru
hey, last time i had this issue it was the coils
so i need new pluge?
Old Sep 24, 2007 | 07:11 PM
But last time you probably werent pouring liquid into the intake mani. Yeah get new plugs or at least take yours out and dry them off.
Old Sep 24, 2007 | 07:23 PM
Tech Guru
they sat all last night should they still be wet
Old Sep 24, 2007 | 07:25 PM
Maybe. They might be sludged up. Take em out and check it out.
Old Sep 24, 2007 | 07:26 PM
Tech Guru
ok
Old Sep 24, 2007 | 08:21 PM
Tech Guru
so i changed my plugs too and it is still acting really funny......almost like i am firing on short cylinders
Old Sep 24, 2007 | 08:45 PM
Tech Guru
oh yeah and it won't boost past 10psi
Old Sep 24, 2007 | 08:46 PM
cantdrive55's Avatar
How about checking what codes it's throwing. Somebody would then be able to tell you the exact cause description.
