Urgent timing belt question
Old May 26, 2006 | 04:07 PM
acetrebo's Avatar
Default Urgent timing belt question
How do I get the fan assembly apart?
I took the fan off, but how do I take off the fan wheel that it is attached to?
I cant get to the bolt behind it to get the last bottom timing belt cover bolt off. Maybe a swivel would work, but I dont have one handy. Is the fan wheel easy or hard to remove?
Old May 26, 2006 | 04:12 PM
techbod's Avatar
Default RE: Urgent timing belt question
the fan wheel is a left hand thread
Old May 26, 2006 | 04:15 PM
Jestnomen's Avatar
6th Gear
You've seen the tutorials right?
http://www.audiworld.com/tech/eng35.shtml
acetrebo's Avatar
So I just turn the wheel to remove it? Holding the pulley still?
Is that what you mean?
Thanks!
Old May 26, 2006 | 04:17 PM
acetrebo's Avatar
Yes, that is the guide i am using.
However, it just says "remove the lower timing belt cover - four bolts.
I cannot get to the 4th bolt because it is behing the fan wheel. I cannot get a socket on it to remove it. it gives no instructions on removing the fan wheel. I have already removed the fan itself.
Old May 26, 2006 | 04:21 PM
techbod's Avatar
anti clock wise mate,
admin please look at your answers its not good to point some one to other sites for answers (if you cant answer then don't )
Old May 26, 2006 | 04:24 PM
techbod's Avatar
even the admin get drunk you know
Old May 26, 2006 | 04:32 PM
acetrebo's Avatar
I am going to try a swivel.
I am not sure what you mean, if I grab the pully with a belt, the fan wheel still spins both ways.
Old May 26, 2006 | 04:35 PM
techbod's Avatar
there are 2 bolt patterns one to hold the other to turn left hand thread
Old May 26, 2006 | 05:11 PM
A4 the Quattro's Avatar
ORIGINAL: avant80@2.6
wtf are you talking about? he was pointing him to one of the best tutorials on the timing belt job.. its not very easy just understand a posters rambling explanation.. but if the tutorial has pics then it helps an assload ...
if someone here would write up a timing belt DIY of that caliber we wouldnt send people elsewhere.. unfortunately we have to...
