V6 30v Camshaft Tool
Old Nov 17, 2004 | 04:55 PM
Daytona A4QV6's Avatar
Default V6 30v Camshaft Tool
I'm kinda in a bind... I finally found a mechanic in my area (daytona) that will do my timing belt/water pump install. One problem.... he does not have the proper camshaft aligning tool (see link below) and will not touch it w/o one. Does anyone know how I could get my hands on one, besides buying one??? I guess I was wondering if someone had one to rent?????
Any suggestions would be greatly appreciated.... I just hit 61k miles on my 89 A4 30V and I'm want to do it ASAP...
http://www.shop.edirectory.co.uk/tru...shaft&cid=1762
Old Nov 17, 2004 | 05:03 PM
Jestnomen's Avatar
6th Gear
Default RE: V6 30v Camshaft Tool
If the 12V and the 30V use the same tool, I have a friend who loaned me his.
Old Nov 17, 2004 | 05:08 PM
ORIGINAL: Jestnomen
no... the 12v is a 15 degree v6 and the 30v is at 60..... the 30v is longer
I am looking at one on ebay, but it's 75$ already and there are 4 days left.....
Old Nov 17, 2004 | 05:11 PM
Jestnomen's Avatar
6th Gear
Just buy one, you can always sell it after you use it.
Old Nov 17, 2004 | 05:12 PM
ORIGINAL: Jestnomen
Yeah... i'm gonna try and get the mechanic buy it.... he he he
If not, I'll just get it, i guess
Old Nov 18, 2004 | 04:43 PM
great day!!!!!
I found a mechanic that has a shop less than a mile from my house. He has all the tools and has done several A-4's (5v).
I'm gonna get this done:
timing belt
snub mount
tensioner/pully
water pump
valve cover gaskets
oil fill gasket (leaking)
new spark plugs
new spark plug wires*
front oil seal*
serpentine belt*
fresh radiator fluid
* if needed
anything else???
Old Nov 18, 2004 | 04:59 PM
Jestnomen's Avatar
6th Gear
wow, that about covers it!
Old Nov 18, 2004 | 05:04 PM
ORIGINAL: Jestnomen
What is a good first mod???? After I get all this shizzz done I want to start doing some upgrades...
I was thinking of an intake
and definately the lights you got from ECS... they are sweet!!!!
then it's wheels..... I was thinking 18 inch is prolly the biggest you want to go on this vehicle, what do you think??
Old Nov 18, 2004 | 05:45 PM
Jestnomen's Avatar
6th Gear
Well you'll want to lower the suspension with coilovers or shock/springs before you add 18" wheels, otherwise you will be driving a monster truck. Yeah 18's are about as large as you want to go, 19's may rub.
Have you considered chiping the car yet? The only other really decent mod is the supercharger but that is 4-5 grand!
Keep in mind with the lights, there will be a little cutting of the fender (can be done with dremel).
Old Nov 19, 2004 | 12:09 PM
ORIGINAL: Jestnomen
I build freestyle jet skis and have no fear of the dremel... I also do my own paint and body and engine work.
my ski....
[IMG]local://upfiles/3321/7C75C8A9514E4BC5A884CB362E36A050.jpg[/IMG]
