vag code 16502
Old Apr 25, 2006 | 06:50 PM
elvis12's Avatar
Default vag code 16502
ok, i know what the code is (engine coolant temp circuit high input)
and yes i did serch it first
but
what part gets replaced
and would there be a los of power, it feels like there is no boost??? like it is back to stock..(from tap stage 2)
thanks
E
Old Apr 25, 2006 | 06:57 PM
brrman's Avatar
Default RE: vag code 16502
The coolant temp sensor gets replaced. $5 part on the rear of the engine - plugs into the end of a coolant hose.
Yes, it could cause lack of power. Is this the only code you have?
Old Apr 25, 2006 | 06:58 PM
CRAZYHAWK's Avatar
You might have to replace the coolant sensor.
Old Apr 25, 2006 | 07:28 PM
elvis12's Avatar
yes, happy to say now it is the only code..
look in (My car is broken. I need some help, please )
i listed the other codes, but they all went when i replaced the ignition module
thanks
E
Old Apr 25, 2006 | 07:44 PM
brrman's Avatar
nice... you should have no problem then - replace that sensor and I think you will be ok.
Jswifto63@yahoo.com
Mar 1, 2012 08:30 PM
jrox1.8t
May 26, 2010 01:03 PM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
tonym
Jun 14, 2006 03:49 AM
