Vag-Com ?
Old Jan 12, 2006 | 11:12 PM
onepoint8tee's Avatar
Default Vag-Com ?
Does anyone know if you can turn off the windshield washer fluid low indicator with vag com ? Ya know that thing that looks like a yellow volcano erupting when your fluid is low? I have had a leak since i bought the car, i will fix it at some point, but i want it out of my face! I have heard that you can unplug the sensor that goes into the resevoir, but i cant get it off because of the limited room to fit a hand down there. That last part sounds bad, but if anyone knows about it id like to hear it. Thanks..
Old Jan 13, 2006 | 09:43 AM
david9999's Avatar
Default RE: Vag-Com ?
Sorry, can't be done.
Old Jan 13, 2006 | 12:39 PM
quattrosedan's Avatar
is there any way to make your back windows go all the way down? or is there something mechanically limited there?
Old Jan 14, 2006 | 02:50 PM
dankhound's Avatar
Mechanically limited by the size of the regulator.
Old Jan 14, 2006 | 02:53 PM
Slowb5's Avatar
honsetly, just crack your driverside window, it looks baller.
if you have tints that is.
Old Jan 14, 2006 | 03:11 PM
techbod's Avatar
replace the sensor or service it ( a little oil works wonders its a float/plunger sensor you know ),
rear window can only go down as far as the rear wheel arch allows
Old Jan 14, 2006 | 03:24 PM
trailboss's Avatar
ORIGINAL: onepoint8tee
I know on the b6 there is a sensor that you can unplug, check and see if there is a sensor you can unplug.
Old Jan 14, 2006 | 03:36 PM
techbod's Avatar
sensors are measured on resistance ( the lower the level turns the light on ) so if you and find the resistance of a full level and put a resistor in there the system will always think its full
