VAG-Com
I need to get a Vag com...does anyone have this kind? or have any suggestions on which ones to get?
http://cgi.ebay.com/ebaymotors/Profe...28984451QQrdZ1
Well you can buy a cable like this one HERE and then purchase the software from Ross-tech for $100. Some mebers have problems with these cables the first one that I ordered didn't work that well then I purchased one from this seller and it works perfect. If all your looking to do is read error codes and clear them, all you need is the cable. You can download software from ross-tech and it will do that for free.
readers do just that and only that read and erase. vag-com can do that plus you can view your AF ratio, check for missfires, make logs with excell that show's how your car is running and can give you signs that somthing is on its way out or not working as good as it should...the list goes on. check out ross-tech.com for more info on what they can do.
