Vag Com ???
Old Feb 5, 2008 | 10:06 PM
trapped's Avatar
Default Vag Com ???
Please help, Im looking to buy a Vag Com cable and i found a few on ebay such as this one
http://cgi.ebay.com/ebaymotors/USB-K...em280196723403
Ok so my question is, If i buy this cable and download the free Vag Com software will i be able to change codes and run tests. If yes then why would anyone spend 200 for a cable and software from Ross Tech?? Please help
Old Feb 5, 2008 | 11:05 PM
trapped's Avatar
Default RE: Vag Com ???
Anyone??
Old Feb 5, 2008 | 11:13 PM
cincyTT's Avatar
I'm make believe
you can only do so much much with the years old version of the sw. if you just want to run codes and a run a few logs, a ebay cable should work. But if you really want to run logs and tune the car plus do other things, you need a real cable. Not to mention not all ebay cables work
Old Feb 5, 2008 | 11:17 PM
auditech79's Avatar
E-bay cables suck! IMO. Don't waste your money on what could be a headache and just spend the God damn $250. Your getting a scanner thats equal to the $5,000 VAS one anyway.
Cheap a** people [:@]
www.ross-tech.com
Old Feb 5, 2008 | 11:22 PM
trapped's Avatar
I know i was going to buy the real one from Ross Tech, but someone on the forums mentioned the ebay cables and i was just curious. Thanks for the help
Old Feb 5, 2008 | 11:23 PM
cincyTT's Avatar
I'm make believe
there is a ton of other stuff you can use it for, it is all listed on the site
