vag com driver
Old Dec 5, 2007 | 06:33 PM
apr_a4's Avatar
Default vag com driver
ok i bought a vag com installed but can use cuz my driver, the driver is made by a ftdi chip and i cant seem to find a driver for vista any help?
Old Dec 5, 2007 | 06:40 PM
cantdrive55's Avatar
Default RE: vag com driver
Which version of Vag-Com? I know that when I boot into Vista and try to use Vag-Com it doesn't work with 311.2
Old Dec 5, 2007 | 06:42 PM
apr_a4's Avatar
409.1
Old Dec 5, 2007 | 07:52 PM
Don't think Vag-Com is going to work with that version. I pulled this right off of the Ross-Tech website:
1.14 Will VAG-COM work on Windows Vista? [blockquote] We have been testing on Vista since December of 2006. Version 7xx of VAG-COM fully supports Vista (both Vista-32 and Vista-64) with a Vista-aware installer and appropriately signed USB drivers. Release 704 can be downloaded here. We will not support any older versions of VAG-COM on Windows Vista. If you get a new PC with Vista already on it, or you upgrade an existing PC to Windows Vista, you should plan to use version 7xx. All interfaces Ross-Tech has sold in since February of 2004 are compatible with Version 7xx, as are many sold before then. If you have an older Ross-Tech interface which isn't compatible, or you're a registered user with a 3rd-party interface, upgrades are available here. [/blockquote]
Old Dec 6, 2007 | 09:50 AM
nihil's Avatar
Since you mentioned its an ftdi usb chipset: http://www.ftdichip.com/FTDrivers.htm
Old Dec 6, 2007 | 01:17 PM
apr_a4's Avatar
its funny because vag com powers on it passes the test and when i plug it it says it dun work
Old Dec 6, 2007 | 01:23 PM
aRIf's Avatar
same thing happen to me and I ended up loading on the laptop which has xp on it. worst case, install xp on avirtual pc on your vista.
ssingh
Apr 1, 2011 06:50 AM
gooddriver?
Dec 25, 2008 11:26 AM
vc1492a
Jun 30, 2008 05:05 PM
damir21
Oct 3, 2007 10:30 PM
