VAG-COM needed in Columbus Area
Old Oct 2, 2005 | 06:56 PM
aRIf's Avatar
Default VAG-COM needed in Columbus Area
Hello,
Yesterday in a parking lot my car just stopped (before push the gas padal, I pulled the cluch pedal that's why), then I started again and there was a cel. I pull the negative side of the battery about an hour and the cel is still there and I think my car is in limp mode now because I cannot go over 4psi. Is anybody can help me the see what the cel says and clean the code ? I want to do it today because I am really busy during the weekdays.
Thanks
Old Oct 2, 2005 | 07:09 PM
Jestnomen's Avatar
6th Gear
Default RE: VAG-COM needed in Columbus Area
Hey see if autozone or advance auto will scan your car. If you can wait a week i'll be home to scan it for you.
Old Oct 2, 2005 | 07:19 PM
aRIf's Avatar
I think I'll wait till you come, because advance cannot clear the code. I'll go advance and see what the cel says...
Thanks Jest.
Old Oct 2, 2005 | 07:26 PM
Jestnomen's Avatar
6th Gear
Well you can clear the code by disconnecting the battery cable for a half hour or so. But if there is a real problem it will just come back.
Old Oct 2, 2005 | 07:39 PM
david9999's Avatar
Or if you don't have the code for your radio, you will have a new problem to deal with.
Old Oct 2, 2005 | 09:30 PM
aRIf's Avatar
ORIGINAL: Jestnomen
I disconnected the - battery over an hour but when I start the car the code just was on there.
Old Oct 2, 2005 | 10:16 PM
aRIf's Avatar
I just back from AdvanceAutoParts
They checked the CEL and there is the message;
P1565
Manf Cnrtl Veh.Spd.
Idle Speed Control
After I got the print out, I got in my car and started to engine and the CEL was off
I drove to home and I could see over 7psi
Car is fine know. Thanks to everybody
Mary#17
Apr 2, 2015 08:50 AM
ccmotorsportsohio
Feb 19, 2014 03:23 PM
tiptothe4
Oct 12, 2010 10:10 PM
jnaught
Feb 18, 2006 10:39 AM
a4ddt
Sep 19, 2005 12:23 PM
