Valves tap on cold start
Old Dec 22, 2005 | 02:58 PM
A4_Spooler's Avatar
Default Valves tap on cold start
It sounds as if my valves are tapping for about a second whenever I start up my 1.8, especially when it is about 10-15 degrees outside, is this normal? any ideas as to why this might be happening?
Old Dec 22, 2005 | 03:02 PM
onepoint8tee's Avatar
Default RE: Valves tap on cold start
ORIGINAL: A4_Spooler
Hydrolic oil lifters.. Its pretty normal... You have the correct oil grade in that engine? If its too thick those lifters will be noisy.
Old Dec 22, 2005 | 05:02 PM
brrman's Avatar
Typical of the 1.8t on cold starts. if it doesnt go away in 5 minutes or so you probably have slight sludge buildup around your lifters. You can use an oil cleaning additive (I used Justice Bros and it worked quite well) or try going to a lighter synth oil to see if it helps the problem.
Old Dec 22, 2005 | 05:10 PM
JoeyZ's Avatar
Same thing happens to my car. I dont like the sound. It "claps" on startup.
I have a 2004 3.0.....
Old Dec 22, 2005 | 05:35 PM
jukeit's Avatar
My try seafoam to clean up the fuel injection system and combustion chamber. Just did this on my car recently. Do a search on this forum for "seafoam". There is a link to a nice write up for 2.8s; however, there is mention in that thread of what to do with the 1.8.
Old Dec 22, 2005 | 06:29 PM
StevenTownsend's Avatar
mine does the same..
Old Dec 22, 2005 | 06:30 PM
JoeyZ's Avatar
Im laughing....love the brutally honest description of your car.
Old Dec 22, 2005 | 06:45 PM
jukeit's Avatar
ORIGINAL: JoeyZ
hahaha. Yeah, my sh*t is stock, typically dirty as f*ck on the outside and is usually broken in some way shape or form. Hopefully I'll knock the cruise control and sunroof problems off my sig before too long.
Old Dec 22, 2005 | 09:00 PM
John_E's Avatar
Does the noise ever return on hot idle? If so, this would indicate oil starvation of the cam chain adjuster, probably due to leaky cam seals.
Are you using a 0W-40 or 5W-40 oil? A course of Auto-RX may help, as well.
Old Dec 22, 2005 | 09:05 PM
ORIGINAL: John_E
Good call on the hot idle..When was the last time you oil was changed?
