vibration
Old Jul 6, 2005 | 09:47 AM
18T's Avatar
18T
Default vibration
Ive been noticing lately that my car vibrates at around 80mph. (75-85 range) it will do it while accelerating gradualy, but if u accelerate fast from lets say 60 to 100 then it wont vibrate. (not the whole car vibrates, i can feel it only in the steering wheel and pedals/shifter)
I can feel alot of the vibration in the gas padel and some in the steering wheel. car has 57k miles on it.
Last time i had something like this happen was on the 1996 Aurora i was driving. engine mounts were all fked up on it.
Old Jul 6, 2005 | 12:17 PM
Danase's Avatar
Default RE: vibration
I would check a few thing first. Wheel balanced, alignment, and just check out the suspension to see if anything feels loose or not.
Old Jul 6, 2005 | 12:25 PM
lidonnit's Avatar
Engine mounts are easy enough to check as well. I would certainly be checking them. . . . If it was only one mount you would more than likely feel a "clunk" when you took off.
Old Jul 6, 2005 | 02:25 PM
18T's Avatar
18T
Its just a strong vibration sometimes at around 75-85
Old Jul 6, 2005 | 02:45 PM
Danase's Avatar
ORIGINAL: 18T
I would for sure check your wheels and suspension first.
Old Jul 6, 2005 | 02:51 PM
18T's Avatar
18T
I had a wheel rotation ysterday. Do they do alignment when they rotate them? Ive had the vibration before they were rotated.
Old Jul 6, 2005 | 02:57 PM
sdaudi's Avatar
i don't think they do alignment when they rotate the wheels.
Old Jul 6, 2005 | 03:01 PM
gjc04's Avatar
I also had a vibration around 80 mph. It turned out to be the Pirelli tires (17,000 miles on the tires). When i bought the car each tire had a different pressure and probably caused uneven wear. New tires fixed it right up.
Old Jul 6, 2005 | 04:47 PM
99a4audi's Avatar
def check alignment, or just take it somewhere and have them check it out and give u a quote. I had that same prob and found out it was my control arm, and wheel bearing
Old Jul 6, 2005 | 05:11 PM
skidplatexa4's Avatar
Check alignment mine is out a hair and I havent gotten in to Mark to get him to align it yet. It has a slight vibration at about 75 - 80. Well I had it in on Friday but his machine was down so he's doing it this friday for me.
