Vibration under accleration
Old Sep 11, 2007 | 01:13 AM
Mr. Merk's Avatar
Member
Default Vibration under accleration
Hey, my girlfriend is looking at buying a 2001 A4 1.8T TIP (fwd) this week
the only thing holding them back is that under acceleration it vibrates and gets worse the faster it goes, said it'll do it in any gear
dont know if its tire related, they are worn poorly from bad alignment
out of balance?
tire wear?
just the alignment?
new CV axles (recently) ?
misfire? (the coil had been popped up but was down when this occured)
Old Sep 11, 2007 | 01:23 AM
auditech79's Avatar
Default RE: Vibration under accleration
Tire vibrations are distinctive, if the tires in the front of the car are out of balance the steering wheel will shake back and forth, if the rear tires are out of balance itwill shake the seat.
If neither of these vibrations are felt it may be a wheel bearing.
Old Sep 11, 2007 | 01:29 AM
cincyTT's Avatar
I'm make believe
my fav are the loose wheel bolts shake [:@]
Old Sep 12, 2007 | 08:54 AM
Mr. Merk's Avatar
Member
99% sure its the reman cv axles...
Old Sep 12, 2007 | 11:10 AM
techbod's Avatar
Default RE: Vibration under acceleration
doubtful^^ ill go for loose bolts or something in that area ( was there this problem before you replaced the CV joints? )
Old Sep 12, 2007 | 12:57 PM
Mr. Merk's Avatar
Member
we are just buying the car today, it has had the cv axles recently, i found another guy on here that had that problem with cheap rebuilt axles
i called the most reputable local german auto shop, described the problem and without skipping a beat he said he's 99% sure its the cv axles, asked if its had rebuilt axles put in recently and i said yes....
Old Sep 12, 2007 | 01:05 PM
techbod's Avatar
basically the drive shaft is the part between the CV joints ( inner and outer ) so if the Axel/half shat was bad then the CV joint was a bad move and the whole half shaft with both CV joints should have been replaced,
dont buy until this has been done chances are the splines on the half shaft are bad and could be expensive repair
Old Sep 13, 2007 | 01:25 AM
Mr. Merk's Avatar
Member
i was referring to the whole cv axle assembly from hub to tranny
rjlavender
Sep 2, 2011 11:28 PM
killaxova
Jan 17, 2008 05:41 AM
abyen
Aug 15, 2007 02:18 PM
Allroad324
Aug 21, 2006 12:05 AM
darchinova
Jul 26, 2006 07:19 PM
