Want to replace timing belt myself.....
Old May 27, 2005 | 04:16 PM
headshok2002's Avatar
Default RE: Want to replace timing belt myself.....
No complaints of horrible vibration?
That is pretty gross... 13 bucks is all you SHOULD pay for one... seems criminal to charge 50 bones for a piece of rubber.
Old May 27, 2005 | 04:22 PM
BFlan2001's Avatar
well....i don't know about you guys...but the greedspeed snub mount isn't showing up on their website anymore....it was there just a day or so ago....
Old May 27, 2005 | 04:33 PM
I know eh, its hard to find it... it shows up in their "featured items" thing that populates in their home page... I dunno if the "featured items" is random and changes with every refresh or what... but I sure couldnt find it in any of the sections (like the section that has the upgraded motor mounts).
Old May 27, 2005 | 05:04 PM
BFlan2001's Avatar
yea, it used to be in the 'engine' category when you browse by model...that's strange.....yea, the 'featured products' page changes each time, i guess that's the only way to find it now.......i think the greedspeed mount is so much cheaper because it's an oe part from an older model audi that they probably got a good price on (i may be wrong about that though)....but they are all just polyurethane bushings (stock is rubber, which is why these are so much better)
Old May 27, 2005 | 05:37 PM
I just worry about the vibration, thats all.
Old May 27, 2005 | 05:52 PM
BFlan2001's Avatar
the only snub mount that i've heard any complaints about is the apr mount, i've heard it's a little stiff and causes vibration when it's first installed. installing it can be tricky too, because of how stiff it is...i have the greedspeed snub mount...but unfortunately it's sitting in my toolbox right now, patiently awaiting installation....i didnt know about changing out the snub mount when i did my tb
Old May 28, 2005 | 07:35 AM
B5T's Avatar
B5T
ORIGINAL: insuite
Yes ... get two pieces of 8mm threaded rod, about 12" long each and you're home free. Same difference for $8 instead of $50. Do yourself a favor and get the ECS Tuning Timing Belt kit with water pump and everything you need. The only thing they leave out is the o-ring between the pump housing and the block, so you might want to get that.
why pay more for the timing belt kit when you can get the same parts for cheaper:
https://www.audiforums.com/fb.asp?m=80464&key=
This is good for AEB and ATW engine codes.
Old May 28, 2005 | 10:58 AM
  #18
david9999's Avatar
Yes, there is a LOT more vibration with a snub mount and a tiptronic. If felt like I had a bee's nest under my gas pedal, until I adjusted it.
I would suggest that if you are doing timing belt, that you replace the front engine cam seals.
Old May 29, 2005 | 01:25 PM
  #19
Is the vibration not so much an issue on a 5 spd car?
EDIT: and yeah, I might change the cam seals on my SECOND t-belt change... right now the car has less than 60K on it... so I'll just do it next time around.
Old May 30, 2005 | 01:03 AM
  #20
thintzen's Avatar
i bought the timing belt kit off ecs tuning for about $280 for my 98 a4 1.8t,,, what else do i have to buy to have all the necessary parts when i do the install.
