WARPED PLASTIC LOWER DOOR TRIMS
Old Jan 5, 2007 | 07:56 PM
18T's Avatar
18T
Default RE: WARPED PLASTIC LOWER DOOR TRIMS
just go buy new ones. the metal rails on the inside rust and brake over time so they start to warm and come out of the tabs.
Old Jan 5, 2007 | 08:01 PM
DENIS415's Avatar
$60 for all four at the stealership??? Im trying to get my lowers painted and my plastic is ripped...looks like im gonna be heading to the stealership right now!
Old Jan 5, 2007 | 08:04 PM
18T's Avatar
18T
ORIGINAL: DENIS415
depends on the dealer. at my dealer if i was to buy it with my employee pricing it would be about 100$
Old Jan 5, 2007 | 09:01 PM
cvpmh1's Avatar
The car is almost 4 years old, is that old enough for the clips and things to have gone?
Apart from the visual things, is there any problem in leaving them like this. No water can get in because of the seal, can it?
Old Jan 5, 2007 | 11:22 PM
tractioncontrol's Avatar
The clips break when removing them.
Yes, leaving them pulled out could cause the door to rust.
Old Jan 6, 2007 | 06:03 AM
18T's Avatar
18T
ORIGINAL: cvpmh1
okay i dont know how you brake the clips but youre not supposed to. the RAILS rust on the moulding itself.
If you want to take off the moulding, it should slide right off since its on rails. and if they are in a really bad state you can just pull it off since the rails hafe disintergrated(sp)
Old Jan 7, 2007 | 12:44 PM
cvpmh1's Avatar
Thanks for your help.
I had a look, there are two screws holding them on, no sign of any clips ever being there. Once the screws have been removed the trim slides of its rail. Looks like it is the plastic whish is curved. Leaving it like this cant damage the car in my opinion, no more water can get to the bottom of the door than when the trim is flush. More can get under the door onto the cill, but this is plastic protected anyway.
arichardgraham
Jul 6, 2009 09:09 AM
apeman
Apr 13, 2009 07:48 AM
nickmerr
Aug 27, 2007 08:56 AM
johnstef
May 18, 2007 02:22 AM
