Washer Fluid Pump
Is there a fuse for the windshield washer fluid pump on the B6's? Mine suddently stopped working the other day (yes I have fluid and no its not frozen...)
This car is starting to show signs of its age... |
RE: Washer Fluid Pump
Its probably a bad pump, they usually develop a crack on them. Take off the belly pan and you should be able to see the pump/s. Take the connector off and check for power.
The fuse# should be on the back of the fuse cover. |
Thanks for the response- is the pump located under the resivoir?
Did you check fuse #37? If it's blown, replace with a 30 amp fuse. Many people are encountering this right now.
