Washer Fluid Pump
Old Dec 20, 2007 | 06:42 AM
tealetm's Avatar
Default Washer Fluid Pump
Is there a fuse for the windshield washer fluid pump on the B6's? Mine suddently stopped working the other day (yes I have fluid and no its not frozen...)
This car is starting to show signs of its age...
Old Dec 20, 2007 | 12:05 PM
auditech79's Avatar
Default RE: Washer Fluid Pump
Its probably a bad pump, they usually develop a crack on them. Take off the belly pan and you should be able to see the pump/s. Take the connector off and check for power.
The fuse# should be on the back of the fuse cover.
Old Jan 14, 2008 | 02:47 PM
tealetm's Avatar
Thanks for the response- is the pump located under the resivoir?
Old Jan 14, 2008 | 03:01 PM
Sherman Banks's Avatar
Did you check fuse #37? If it's blown, replace with a 30 amp fuse. Many people are encountering this right now.
MartinCieslak1
Feb 25, 2011 07:51 AM
AudimaniaA4
Jan 4, 2011 08:23 AM
mypreludeisred
Jul 18, 2009 09:06 PM
Willfulone
Jan 26, 2005 01:58 PM
