water behind driver seat in floorwell
Old Feb 19, 2006 | 06:24 PM
jits1980's Avatar
Default water behind driver seat in floorwell
hey guys i have a huge problem on my 99 audi a4. everytime it rains i get water behind the driver seat on the floorboard. I cant seem to locate the problem. anyone with any ideas please email me at jits1980@comcast.net. I have checked both drains in the engine compartment and also the front sunroof drains. i dont know if there are any rear sunroof drains if so please tell me where i can locate these so i can check them. Please email me with any help
Jits
Old Feb 19, 2006 | 06:27 PM
TroyS's Avatar
Default RE: water behind driver seat in floorwell
Does it smell like coolant? Hope not. If so, its a leak in the cooling system behind the dash.
One thing to do would be to take a garden hose to it.
Old Feb 19, 2006 | 06:31 PM
dan908's Avatar
Somebody had a problem recently with water in the A pillar behind the drivers door shorting stuff out. Said it was a clog in the sunroof drain.
I got some water recently in my pillar that got the seat belts and floor mats wet from the same problem (of course it did rain 7 inches that day so I kind of feel that it was not Audis fault) Check into sunroof leakage and drainage.
Old Feb 19, 2006 | 06:34 PM
18T's Avatar
18T
^ yeah thats what it is most likely
Old Feb 19, 2006 | 07:08 PM
Jestnomen's Avatar
6th Gear
Yep I agree most likely the sun roof drain.
Old Feb 19, 2006 | 07:17 PM
jits1980's Avatar
how many sunroof drains are there on the 99 a4? i have located the front 2, but i cant seem to locate the rear if there are any
Old Feb 19, 2006 | 07:34 PM
Jestnomen's Avatar
6th Gear
The front drains go down the A-Pillars. The rear drains down the rear of the car. So you only need to clear the front two. I'd try to get some compressed air to blow those suckers out.
Old Feb 19, 2006 | 09:49 PM
jits1980's Avatar
the two front drains are draining properly...do you know of any other causes of this water showing up behing the driver seat floorwell? thank you in advance
Old Feb 19, 2006 | 10:22 PM
ckandes1's Avatar
ORIGINAL: jits1980
Dn't cancel ut the two front drains so quickly! My front drains drain properly also. or so it seems! but if i put a gallon of water down the front left drain water will start gushing at the bottom of the a-pillar in the dash and down to the driverside floorba\oard. From there it will run along the side of the car and puccle up at the floorboard in the back. Probably the same place you're finding water. Follow the water to see if there is a track of it along hte left side leading to the front. if so, it'd be the sunroof drain. If you SEARCH you will find my post on this WITH PICTURES
Old Feb 20, 2006 | 06:03 AM
TroyS's Avatar
https://www.audiforums.com/m_162826/.../tm.htm#168525
