Water leaks in car!!!???
Old Nov 26, 2007 | 01:11 AM
thecheda's Avatar
Default Water leaks in car!!!???
just washed my car and the upholstery near the rear seat headrest ceiling was damp with water. Where is this leak? Damp on both rear ceiling.
Old Nov 26, 2007 | 01:27 AM
ocadam's Avatar
Default RE: Water leaks in car!!!???
probably there is a hole in the back window.
Old Nov 26, 2007 | 03:47 AM
thecheda's Avatar
hole in the weather strips on the back window? or the back window itself. i would think the weatherstripping.
Old Nov 26, 2007 | 08:43 AM
hiwords's Avatar
cover up that area that was wet and water test the rear window and then water test the sun roof. don't do it at the same time
Old Nov 26, 2007 | 11:31 AM
thecheda's Avatar
if it is a whole in the back windshield weatherstripping, how much does something like this cost to fix?
is there even a diy for this type of deal?
Old Nov 26, 2007 | 11:35 AM
new2me's Avatar
If you have a sunroof then the drains are most likely clogged.
Old Nov 26, 2007 | 12:00 PM
thecheda's Avatar
i found a small section on the topside of the back windshield that has a part of it punched in. Could this be the cause? Ill water check this spot later.
Old Nov 26, 2007 | 12:02 PM
thecheda's Avatar
there is a part of the upholstery that is discolored. any remedies for this?
Old Nov 26, 2007 | 03:41 PM
tatensty's Avatar
Member
Im sorry to use your post hope you don't mind. i have some type of leak when i wash my car all four of my door seals are wet and i have to dry them. i think it may be th rubber stops but i don't know.
Old Nov 27, 2007 | 03:55 AM
thecheda's Avatar
anyone?
