weirdness from the rearend
Old May 20, 2007 | 05:38 AM
dombombBMX's Avatar
Default weirdness from the rearend
hi to all the audi lovers... if you could help try to diagnose this problem that would be so awesome....
first question i have is..... I hear a slight humming from the rear end, maybe a ever so slight kind of grinding noise.. it goes away when i turn right. stays when i turn left. it isnt the brakes, i have applied pressure and the pattern of the sound doesnt differ... it doesnt sound to serious but i just want to know what it might be... just hearing this weird noise you know is not suppose to be there is annoying. i dont know as much as most guys that post here so any help is greaty appreciated...
also... i see small specs/dots of what might be rust forming? if it is how can i stop this from forming bigger... any tips?
thanks in advance
Old May 20, 2007 | 08:33 AM
CRAZYHAWK's Avatar
Default RE: weirdness from the rearend
Right wheel bearing needs replacement.
Old May 20, 2007 | 02:36 PM
dombombBMX's Avatar
alright.. yeah that sounds like it might be the problem.. i thought it might be.. ill probably get some new wheel bearings and see what happens...
if anyone has any other suggestions let me know.
anybody know anything about this rust nonesense?
take it easy alll
Old May 20, 2007 | 02:41 PM
techbod's Avatar
Default RE: weirdness from the rear end
jack each wheel of the ground an spin them and listen for bearing noise ( there should be no noise at all ) just simply a smooth rotation
Old May 22, 2007 | 03:28 AM
dombombBMX's Avatar
you can just jack one wheel up, and spin 1 wheel on an all wheel drive car.... wont the other wheels spin aswell?
anybody have any suggestions on what that odd noise could be...?
thx peoples
Old May 22, 2007 | 05:40 AM
Belligerenceā„¢'s Avatar
ORIGINAL: dombombBMX
thx peoples
no, the diffs on our cars are not limited slip, unfortunately. you can jack up any one wheel and spin it, provided the car isn't in gear. if you tried to spin both rears or both fronts, that's where you'd have a problem.
Old May 22, 2007 | 06:42 AM
david9999's Avatar
Wheel bearing most likely.
Old May 22, 2007 | 10:13 AM
Redrum1's Avatar
Does it make the noise on all types of road surfaces? Mine has a set of GoodYear Eagle RS-A that were on it when I bought it and on certain road surfaces like the brushed concrete they howl like all the bearings were gone. As soon as the road surface changes they run quiet again. Just thought I would throw this in the mix. If the tires are ruled out I would say wheel bearing also.
Old May 22, 2007 | 10:45 AM
BaconBait's Avatar
Wheel bearings also have a tendancy to go out in pairs. Myrear rightwent out and a week later the left went.
Old May 22, 2007 | 11:58 AM
ironman's Avatar
i replaced one wheel bearing already and i dont raelly want to do another one.
