What is 1n 1...it is on my odometer
no its an older B5, it says it because its Inspection 1, basically you need to change your oil.. they are set to go off at intervals, so once you get your service done, and the dealership or mechanic resets it, it will come back on in about 5000 miles, or whatever it is set too, if you get VAG-COM from Ross-Tech, then you will be able to go in and reset the service indicator, and change the intervals for when it comes on.
