what is this??
Old Jul 16, 2007 | 07:09 PM
d3m0nz3y3's Avatar
Default what is this??
I was wondering if someone can tell me what is that part marked in red? It sits right on top of my air filter, and today i noticed a clicking noise from it. I have a 99.5 2.8q... Any help will be much appreciated, also is it something important and needs urgent attention?
Thanks
Old Jul 16, 2007 | 07:22 PM
auditech79's Avatar
Default RE: what is this??
Thats the N80 valve for the evap system. Its supposed to click, if its bad you'll get a check engine light for the evap system incorrect flow ect.
Old Jul 16, 2007 | 07:37 PM
A4Steve's Avatar
That's wierd, I was just wondering that myself. Mine clicks louder once and awhile when I first start it up, is that normal?
Old Jul 16, 2007 | 07:54 PM
auditech79's Avatar
When it clicks louder do you ever notice that your fuel tank is usually full? It works overtime a lot more when you guessed it topping off your tank, don't do that. Eventually it WILL click louder and eventually fail, but if it hasn't failed yet no reason to replace it.
Old Jul 16, 2007 | 08:36 PM
A4Steve's Avatar
No, just sometimes it does it out of the blue. I did just fill up today but I never top it off, in any of my vehicles. At first it sounded like it was coming from the rear of the pass. side valve cover but I tracked it to that valve.
Old Jul 16, 2007 | 08:40 PM
auditech79's Avatar
Don't sweat it too much then its normal. If the noise bugs you you can pay around $100 for a new one but it will still click you probably just won't notice it as much.
Old Jul 16, 2007 | 09:56 PM
d3m0nz3y3's Avatar
this might be a very newbie question, but whats the purpose of this valve? what does it actually do? Thanks in advance for your time :>..
Old Jul 16, 2007 | 10:01 PM
auditech79's Avatar
I believe it cycles the vapors of gas from your gas tank into the charcoal canister back into the intake to be burned in the engine so your not venting it into the atmosphere. Don't worry i bet half of the 30 some odd thousand members on here don't know what it does.
Old Jul 16, 2007 | 10:07 PM
A4 Effort's Avatar
^^ learn something new every day.
Old Jul 16, 2007 | 10:26 PM
d3m0nz3y3's Avatar
thanks for the quick reply, much appreciated. Since you guys are already helping out, one last question. When i turn my AC on, the fan in front on the engine starts to get really loud. Is this normal? i noticed the same thing in my friends A6...can anything be done to make it less noisy?
Thanks
