What Amp to use
Hey im getting my old sub back from my cusin
i let him have it but since he has a new car and doesnt want it
i took it back
its an older veriosn Audiobahn ALUM12Q
i was wondering wats a good amp to use on it
ill be keepin my stock headunit and mose system so ill be tapin the stock amp or something
heres the specs
Features of the Audiobahn ALUM12Q include:
[ul][*]120 oz. Double Stacked Strontium Magnets[*]Power Handling: 1000 watts R.M.S.[*]Frequency Response: 18Hz - 500Hz[*]Efficiency: 96.4dB[*]PHAT 1.75 Inch EPDM Rubber Surround[*]Spun Aluminum Cone[*]3 Inch 4-Layer ASV Voice Coil[*]Dual 6 Ohm[*]3 Ohm or 12 Ohm Operation per sub
[ul][*]1 ohm operation for 3 subs ran in parallel (1.5 ohms for 2 subs)[/ul][*]Multi-connect Lug Lock Terminals[*]Mounting Dimensions: Depth; 5 5/8 Inch Hole; 11 1/8 Inch Diameter; 12 3/4 Inch[/ul]
i took it back
heres the specs
I sell the jl clean sweep but someone very experinced needs to install the unit. It is good stuff. Jl is very reliable i say get rid of ur audibhans i probably fart louder than them just kidding but u will hear the difference got for jl
