what is the gain from the turbo inlet
Old Nov 13, 2006 | 04:43 PM
Sp33d07's Avatar
Default what is the gain from the turbo inlet
i seeen the turbo intlet on awetuning, what is the effects or gains you get from it?
Old Nov 13, 2006 | 05:10 PM
Amze's Avatar
Default RE: what is the gain from the turbo inlet
Can someone tell me what injectors do, while your explaining the other one Would like to learn about both!
Old Nov 13, 2006 | 05:42 PM
smokeU's Avatar
i doubt there is any noticeable gain it only restricts the air less with smoother material.
ORIGINAL: Sp33d07
Old Nov 13, 2006 | 05:54 PM
onepoint8tee's Avatar
ORIGINAL: Sp33d07
So... You just ignore product descriptions or what?
Old Nov 13, 2006 | 06:11 PM
Lazer Viking's Avatar
injectors ? as in fuel injectors ?
fuel injectors moderate the amout of fuel entering the combustion prosses
if you get bigger ones more fuel will flow into the motor
injectors can get clogged and it will effect the "spray pattern" and render performance, or would starve that particular cylinder of fuel and lean it out and cause the piston you more or less melt through
Old Nov 13, 2006 | 10:00 PM
juice88's Avatar
all it does is prevent collapse with a bt under high heat
RyanSweeney
Apr 25, 2011 06:14 PM
oneslowms3
Oct 13, 2010 06:31 PM
AudiTurbo
Sep 9, 2009 08:59 AM
CampbellsChunkySoupr
Mar 28, 2008 12:12 AM
B5luver
Apr 24, 2007 01:13 AM
