What oil for 2002 A4 1.8T
i use mobil 1 too but i use 5W-30 in it. Runs good. I have also used 10W-30 in it also worked fine but make sure whatever grade u use that it is synthetic is much better as said above.
In a climate where it gets colder than 5 degrees use 0w, in climates where it does not get colder than 5 degrees use 5w. The weight is base on the temp. With 5w the oil begins to thicken to the point it doesn't flow well at 5 degrees ferinhieght. With a turbocharge motor this can cause you turbo to be oil starved at startup.
