What should I use to lube the door hinges and gas cap door?
Old Jan 29, 2007 | 12:04 AM
SMoLiK's Avatar
Default What should I use to lube the door hinges and gas cap door?
SMo'
Old Jan 29, 2007 | 09:45 AM
david9999's Avatar
Default RE: What should I use to lube the door hinges and gas cap door?
Lithium grease
Old Jan 29, 2007 | 12:40 PM
CRAZYHAWK's Avatar
^ +1, white lithium grease
Old Jan 29, 2007 | 12:55 PM
akielb's Avatar
KY - the "original" kind - not the "heating" kind - that would cause your car to overheat
Old Jan 29, 2007 | 04:05 PM
tcuphigam's Avatar
oops, I used a dash of silicon spray on my driver door for a quick fix. It has been fine ever since, should I put sone lithium grease on as well or am I okay?
Old Jan 29, 2007 | 05:05 PM
CRAZYHAWK's Avatar
Silicone lubricant is good, but white lithium grease lasts much longer
dvmorris
Mar 26, 2013 02:47 AM
knerml
B7 Models
Apr 7, 2009 02:57 PM
98A4V6
Dec 10, 2005 02:23 AM
98A4V6
Dec 10, 2005 02:21 AM
