what should u do first
Depends on budget, motor type, and go versus show.
go
For under a grand 1.8. Chip, exhaust.
For under a grand 2.8. Exhaust, intake.
show
Tints, swar bars, upgrade to 1 piece headlights, 99+tails, clear side markers, debaged, clear corners, black out grill, paint your unders
Did you do a timing belt yet?
go
show
First thing you should do is get it right.
Make sure TB is done.
Change oil, brake fluid, check anti-freeze, ect.
Make sure brakes are good, yada-yada-yada......make sure everything on car is in good working order before you start to mod. Otherwise, you may be spending money on mods that you need to spend on the car just to get it right.
Then, once you are sure thats all done, get a chip, then exhaust.
Then ask us some more questions AFTER you search for the answers.
