What year Audi should I look for?
I have a A4 1.8T 2001. I moved up from the A3 and couldn't believe the power diffrence.
although i've had a few probs with it, having said that i did buy it from crappy carcraft[:@]
DONT GO THERE. But yes the A4 is a good choice...
But what do i know[&:]
ORIGINAL: HouseOfAtlas
Thanks again for the added input. I don't really plan on making more HP from my Audi, but I might. Not really sure. Although, 200hp is all I really need I think. My dad has a 4 cylider (no turbo) Acura manual and I love that thing. It gets going better than my 2.2L S10 that I used to have. So, anything with over 150hp will be just fine.
99.5....none of that elctronic throttle cable ****. 1.8t, 2.8, auto, or manual all depends on what your looking to get out of the car, and there are plenty of threads to serch for that.
Thanks for all the added input, guys. All of it is very much appreciated.
I noticed an A4 for sale that had the water pump and timing belt replaced at 70k. Is this normal? Or just bad luck?
normal, I had my t belt, water pump, drive belt, cam and crank seals as well as thermostat at like 66k.
ORIGINAL: liquidxit2
Any estimate on the cost to replace the t-belt, water pump, and seals?
Damn! My S10 never had the water pump or seals replaced. Although, maybe I never realized the seals were bad or I just got lucky.
Be prepared to pay around $1500-$2000 at a dealer though.
The only part that fails is really the tensioner which if fails you could end up with a lot of bent valves and possibly more. Most people will do the thermostat & water pump & all the other stuff that is accesable as preventative maintnance.
You can buy a kit that has everything for like $300 at ECS.
