WHEEL SPACERS
Old Dec 30, 2005 | 02:52 AM
Sp33d07's Avatar
Default WHEEL SPACERS
any of you guys have wheel spacer installed on your car if you can post up pics i want to see how does it look on a4's and many ppl says it gives better attraction and other stuff but is there anytthing bad four your car??
Old Dec 30, 2005 | 03:16 AM
flyboy's Avatar
Default RE: WHEEL SPACERS
you can do it alittle but the big thing is you really need the backspacing or you will blow the wheel barings out. other than that they make the car look alot better. get the good ones thou. from H&R on ecstuning.com.
Old Dec 30, 2005 | 03:37 AM
brent07's Avatar
so its ok to use wheel spacers or not ? ...
Old Dec 30, 2005 | 03:44 AM
Beer Mod's Avatar
It depends on how much. more spacer = less bearing life
Old Jan 1, 2006 | 02:52 PM
Sp33d07's Avatar
hmm ok thax alot
Old Jan 1, 2006 | 06:43 PM
robsilvr85's Avatar
Member
I've had the same question also. so around 5-10mm is OK right? i know 20mm is overkill.
Old Jan 1, 2006 | 07:48 PM
tip5's Avatar
With that fitment, you'd want 25mm spacers.
That will keep the wheels flush with the edge of the fenders perfectly.
25mm spacers include lug bolts as well.
Thank you
PURE Motorsport
--------- Original Message --------
To: Info <info@purems.com>
Subject: RE: Wheel spacers.
Date: 19/12/05 08:31
> Enkei cdr9 here's the specs.
> 17 x 7 | 5 x 100 | 5 x 112 | 40
> -----Original Message-----
> From: Info [mailto:info@purems.com]
> Sent: Monday, December 19, 2005 4:15 PM
> To: Vaughn, Richard
> Subject: Re: Wheel spacers.
Old Jan 1, 2006 | 07:53 PM
tip5's Avatar
You have to tell them what your offset to determine what the right spacer is going to make your wheel stick out and no 20mm isnt overkill ive seen 38mm+ on a tt (widebody)
Socalsteve
Jul 16, 2013 02:34 PM
BONDFIRE
Apr 9, 2010 10:05 AM
paparose_12
Jan 10, 2008 01:26 PM
audiant
Dec 1, 2006 09:20 PM
cgv988
Sep 1, 2005 09:02 PM
