Whining noise...
Old Nov 12, 2006 | 02:06 PM
QuattroChucko's Avatar
Default Whining noise...
I've been trying to figure out this whining noise I hear in my car. At 3200 rpm and sometimes at 2600 i hear a whining noise, it goes away when the car warms up, but while the motor is still cold I can hear it. Anyone else have this issue or have any ideas about it? I searched but couldn't find anything remotely close to this problem. [sm=headbang.gif]
Old Nov 12, 2006 | 02:11 PM
techbod's Avatar
Default RE: Whining noise...
it could be nothing apart from a cold start issue, it it doesn't cause a problem like CEL coming on then there is little to worry about
Old Nov 12, 2006 | 02:17 PM
onepoint8tee's Avatar
Could be old bearings in one of your pulleys for your belts, and they just need to move and heat up a little to stfu. Could also be a worn power steering pump struggling to get fluid flow through it on a cold start up. Check fluid levels of course because another thing it could be is a starving water pump acting the same way as a struggling power steering pump on a cold start. Could be an overly tensioned belt that needs to heat up a little to expand to stfu too.
If all else fails, put the wife in the trunk and see what happens.
Old Nov 12, 2006 | 02:18 PM
techbod's Avatar
as well
Old Nov 12, 2006 | 02:30 PM
acetrebo's Avatar
Is your wife or GF in the front seat while this happens??
Old Nov 12, 2006 | 02:32 PM
ORIGINAL: onepoint8tee
It did start once i replaced the timing belt/tensioners/belts and water pump, as long as it's nothing major, I'll just crank the stereo up...That should drown out the wife in the trunk too...
Old Nov 12, 2006 | 02:34 PM
ORIGINAL: acetrebo
When she's in the front seat it's more of a nagging/bitching noise...
Old Nov 12, 2006 | 03:57 PM
Amze's Avatar
Lmfao.
Old Nov 12, 2006 | 04:01 PM
chaos92287's Avatar
ORIGINAL: 98.5quattroA4
lol thats y u gota put her mouth to better uses while you drive
Old Nov 13, 2006 | 12:38 AM
turbo kraut's Avatar
Tech Guru
got aftermarket stereo, ie power wire for an amp?
