whining sound in speakers
Old Jul 22, 2007 | 01:48 AM
TeeterTawter's Avatar
Default RE: whining sound in speakers
haha, it all works, no more whining, no more buzzing, no static. I rewired from where the stock amp use to be, back to my aftermarket amp with insulated speaker risers coming from the stock speaker risers with rca connectors. no hi/lo adaptors, no ground loop isolators, and no more sounds. I will take a pic tomorrow and show wtf i did.
thanks for the help too!
Old Jul 22, 2007 | 09:57 AM
howe0822's Avatar
the problem could be either a bad/loose ground location, a ground loop, or the gains and level adjustments on the amp could be too high.
Old Jul 22, 2007 | 10:30 AM
new2me's Avatar
Nice! Its amazing how well things work when they are properly installed. [:-] Just joking!
Old Jul 22, 2007 | 10:02 PM
pa4ul's Avatar
How do u have your amp hooked up with the rca's? Did u use a converter. That might be the problem a bad converter. I have my amp ground located right underneath my rear seat on one of the bolts. If u need a pic lemme know. But check your converter if you are using one. I had the problem and had to buy a new one. Fixed it right away.
Old Jul 23, 2007 | 12:29 AM
sdsteez's Avatar
well my buddy had that happen when he ran the rca's and power through the same side. he then ran them seperately and that noise was gone. i just put in my infinitys last week and ran it to a 4 ch amp and im getting the exact same problem as you. im going to an audio shop tomorrow morning the guys there will fix it in no time because i already messed with all the grounds and that didnt help.
Old Jul 23, 2007 | 02:44 AM
kraylon's Avatar
the sound you are hearing is called alternator whine it is caused by 2 things 1 bad ground 2 the power wire and the rca for a full range (your 4 channel) can't run on the same side as the car. if they cross paths for an reason try to do it at a 90 degree angle.
Old Jul 23, 2007 | 02:09 PM
sdsteez's Avatar
if he ran the power and speaker wire for the front door panel speakers, couldnt that be the problem too if they crossed?
HulkB5
Feb 28, 2012 07:53 PM
HulkB5
Sep 29, 2011 11:55 AM
mel23816
Sep 1, 2010 11:20 AM
Ashishin
Dec 30, 2008 03:02 PM
audibee5a4
Oct 19, 2006 08:28 PM
