White sludge?
Old Dec 30, 2005 | 08:04 PM
MadIce's Avatar
Default White sludge?
I have a 97 2.8l with 102k.
Ever since I bought the car I've been noticing some white sludge on the oil cap. I had a similar problem with this on a older car and it was from the previous owner rarely changing the oil. It eventually went away on my old car since I keep up with oil changes, but was intrested to here what you guys thought about this?
Old Dec 30, 2005 | 08:32 PM
VitaminB6's Avatar
Default RE: White sludge?
The one time I've had this problem (on an old muscle car), the coolant was seeping into the oil. I ended up getting rid of that motor anyways, since the rings were shot and it wasn't worth rebuilding.
Old Dec 30, 2005 | 08:51 PM
dan908's Avatar
Yeah usually white crap on your oil cap is coolant.
When you changed the oil was it kind of milky (like a cappucino)?
Have you noticed a loss of coolant?
Old Dec 30, 2005 | 08:59 PM
ZedEx's Avatar
Water or Coolant in your Oil... Bad Head Gasket, sounds like.
When we had a huge rain fall one day, my buddy got ran into a puddle ('94 Honda Civic, H22A Swap), and the intake sucked up water. We got it to the shop, and drained the oil... It had already turned into chocolate milk (Water sucked in through the oil breather connected to the intake pipe, the water in the engine wasn't a problem, there wasn't enough to bend a rod), so we changed the oil, and gave it a start... *PING*... Bye, bye rod bearing. [:'(]
Anyway, it sounds like you've got a bad Head Gasket... Run a Compression Test and report back with numbers. Also, check your Coolant Reservoir, and see if there's Oil in there. If so, it's definately a Head Gasket.
Old Dec 31, 2005 | 04:22 AM
specialK4's Avatar
leaking headgasket, oil is mixing with something else, check the tubes in ur car see if they are cracked... sux if ur headgasket is leaking :/
Old Dec 31, 2005 | 04:27 AM
audiboy1618's Avatar
Text book headgasket.
Old Dec 31, 2005 | 04:29 AM
flyboy's Avatar
well jest was having similar probs jsut cus of condensation I think. might want to ask him.
Old Jan 2, 2006 | 08:48 PM
MadIce's Avatar
Well when I did my last oil change nothing came out milky or unusual. I checked my coolant and that seems to be just fine. I decided to pull the head covers off and the tops of them were filled with this milky sludge. I then I pulled the oil breathers connected to the intake pipe and the white sludge was on the whole 1/3 bottom of those tubes.
So I basically went threw and cleaned out the head and the tubes. My guess is that their was condensation and the previous owner never checked or cared. Its been almost a week since I cleaned it out and everything seems to be running fine... my MPG actually seems to be a little higher also (But I'll check that after a few cycles). So I'll be keeping a eye on it to see if this continues.
Old Jan 2, 2006 | 10:12 PM
specialK4's Avatar
yea i'd keep checking it. my friend had a headgasket leak and he had that white crap on his oil dipstick and other places **** was comin out his ***.
Old Jan 3, 2006 | 02:29 PM
Slowb5's Avatar
ORIGINAL: specialK4
gaaah.....
A4 Effort
Apr 9, 2008 08:56 PM
vintravaia
Feb 1, 2008 07:19 PM
tha5150
Feb 2, 2007 04:03 AM
mandeepkang
Dec 22, 2006 01:36 AM
cubsfan
Aug 21, 2006 12:08 AM
