White smoke out of exhaust.. Need help
Old Jun 24, 2012 | 08:10 PM
Jchockey100's Avatar
Default White smoke out of exhaust.. Need help
So the smoke has been happening for 2 months now and it's starting to annoy me! I have checked the oil to see if the oil is milky and checked the colant resivor for oil in it. Neither had those symptoms. It is not smoking all the time and boost gauge says 12lbs of boost at 4k rpms in 4th. I'm trying to figure out if it's head gasket or a turbo going wrong. Please let me know what you guys think is wrong. I'd love to get this car fixed so I can stop racking the miles up on my 05 s4
Old Jun 24, 2012 | 10:07 PM
Correction it only smokes when I downshift. Any thoughts would be helpful. Thank you in regards to responses
Old Jun 26, 2012 | 01:37 PM
Bump, please does anyone know what is wrong with my car??
Old Jun 26, 2012 | 01:48 PM
Vincent Borelli's Avatar
My best guess would probably be either the Turbo, or bad valve stem seals.
Old Jun 26, 2012 | 04:57 PM
brrman's Avatar
White smoke typically means leaky turbo, but the death of the turbo is accompanied by the dentist drill sound.
Old Jun 26, 2012 | 05:23 PM
Thank you guys for the ideas. The turbo started a whineding sound yesterday. Which of the two do you think it is turbo slowly going or bad stem valves?
Old Jul 11, 2012 | 06:06 PM
BeatjunkieXL's Avatar
turbo
Old Jul 12, 2012 | 08:50 AM
I have checked the bearing of the turbo when I put my fmic on 3 days ago and there's no shaft play at all.
Old Jul 12, 2012 | 01:38 PM
z28pete's Avatar
Bad valve stem seals wiil usually produce blue smoke (oil burning) while the car is coasting in gear. High vacuum condition sucking oil into the combustion chamber past the valve seals.
Old Jul 12, 2012 | 04:28 PM
What you just explained for what a bad valve stem seal color of smoke doesn't match up to mine. So it's leading me to I gotta change my turbo.
