Whoaa, My fault codes..
Old Feb 26, 2006 | 09:25 PM
Karl's Avatar
Default Whoaa, My fault codes..
8 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 92-00 - Unknown Error Elaboration
17817 - EVAP Purge Valve (N80): Electrical Malfunction
P1409 - 92-00 - Unknown Error Elaboration
17808 - EGR Valve (N18): Electrical Malfunction
P1400 - 92-00 - Unknown Error Elaboration
17919 - Intake Manifold Valve (N156): Electrical Malfunction
P1511 - 68-00 - Cylinder 1
16545 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit Malfunction
P0161 - 92-00 - Unknown Error Elaboration
16525 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit Malfunction
P0141 - 92-00 - Unknown Error Elaboration
16539 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit Malfunction
P0155 - 92-00 - Unknown Error Elaboration
16519 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit Malfunction
P0135 - 92-00 - Unknown Error Elaboration
Old Feb 26, 2006 | 09:26 PM
cary12's Avatar
Default RE: Whoaa, My fault codes..
OMG. Good luck with all that bro.
Old Feb 26, 2006 | 11:42 PM
Jestnomen's Avatar
6th Gear
Have you cleared them to see if they come back?
Old Feb 26, 2006 | 11:44 PM
Karl's Avatar
yeah, cleared them yesterday and they came back today.. while searching around AW, a guy had all of the exact same codes as me (except the coolant temp) but he never got any answers.. so it makes me think it could be 1 small problem causing all these codes
Old Feb 26, 2006 | 11:51 PM
Jestnomen's Avatar
6th Gear
Well ya might want to start with the Coolant temp sensor, they can cause some crazy problems.
Old Feb 26, 2006 | 11:52 PM
Karl's Avatar
yeah, but i dont think that it would cause emissions problems, unless im missing something
Old Feb 26, 2006 | 11:55 PM
rbrtech's Avatar
Those are a lot of codes lets see if I can help give me your car info please.
Old Feb 26, 2006 | 11:57 PM
rbrtech's Avatar
you ar a 97 a4 1.8 or 2.8
Old Feb 27, 2006 | 12:00 AM
rbrtech's Avatar
p0116
Engine Coolant Temperature (ECT) Sensor, Checking
Required special tools and test equipment
VAG 1551 or VAG 1552 Scan Tool (ST) with VAG 1551/3 adapter cable
VAG 1598/22 test box
Multimeter US 1119 (Fluke 83 or equivalent)
VW 1594 connector test kit
Wiring diagram
Test requirements
Engine cold
Checking
Connect VAG 1551 or VAG 1552 scan tool and press buttons -0- and -1- to insert "Engine Electronics" address word 01 (with ignition switched on). See: Scan Tool Testing\Scan Tool Connecting and Initial Checks\Connecting VAG 1551/1552 Scan Tool
Indicated on display
Rapid data transfer
Select function XX HELP
Press buttons -0- and -8- to select "Read Measuring Value Block" function 08, and press -Q- button to confirm input.
Input display group number XXX HELP
Press buttons -0-, -0- and -1- to input display group number 1, and press -Q- button to confirm input.
Indicated on display (1-4 = display fields)
1 2 3 4 ->
Compare display with specified value for engine coolant temperature sensor (display field 2):
Display Group 1
Start engine and let run at idle.
Temperature value must increase evenly
NOTE:
Temperature is displayed in increments of 1.5 °C.
If engine performance problems occur within certain temperature ranges, and if the temperature values do not increase without interruption, the temperature signal is intermittently interrupted and the sensor must be replaced.
If NOT:
Replace Engine Coolant Temperature (ECT) sensor -G62-.
Press -> button to advance program sequence.
Press buttons -0- and -6- to select "End Output" function 06, and press -Q- button to confirm input.
Switch ignition off.
Evaluation of display group 1
Display Field 2
Checking wiring
Connect VAG 1598/22 test box to ECM harness connector. See: Scan Tool Testing\Scan Tool Connecting and Initial Checks\Connecting VAG 1598/22 Test Box
Disconnect 4-pin connector from ECT sensor -G62-.
Check wiring resistance for open circuit between ECM/test box and 4-pin ECT sensor connector.
Connector terminal 1 to ECM/test box socket 53
Connector terminal 3 to ECM/test box socket 67
Specified value: max. 1.5 Ohms
Check wiring for short circuit between ECM/test box and 4-pin harness connector according to wiring diagram.
Connector terminal 1 to vehicle Ground
Connector terminal 1 to ECM/test box socket 67
Connector terminal 1 to terminal 3
Connector terminal 3 to vehicle Ground
Specified value: Infinity Ohms
Check wiring between ECM and 4-pin harness connector for short circuit to battery B+. Specified value: 0 volts
If wiring is OK:
Check ECT sensor resistance across terminal 1 (signal) and terminal 3 (ground).
Check measured resistance value for appropriate temperature range using graph below (N24-0157).
Range A: 0 to 50 °C
Range B: 50 to 100 °C
Examples:
At 30 °C , ECT sensor resistance should be 1500-2000 Ohms
At 80 °C , ECT sensor resistance should be 275-375 Ohms
If resistance is NOT OK:
Check readiness code. If Diagnostic Trouble Code (DTC) memory has been erased, or ECM was disconnected, generate new readiness code.
See: Monitors, Trips and/or Drive Cycle (Readiness Codes)\Readiness Code Reading
See: Monitors, Trips and/or Drive Cycle (Readiness Codes)\Readiness Code Generating
Old Feb 27, 2006 | 12:02 AM
Jestnomen's Avatar
6th Gear
It actually does a lot.
http://www.aa1car.com/library/2004/us10438.htm
