Wierd Brake Problem
Old Sep 12, 2007 | 11:03 PM
superfly78209's Avatar
Member
Default Wierd Brake Problem
My brakes squeel like crazy and have since I bought the car around a month ago. But only in the morning or if I haven't drived the car for a specific amount of time. Sounds horrible and it real high pitched. After about 5 or so good brakes on my commute it will go away. Any explanations? Thanks
Old Sep 12, 2007 | 11:10 PM
cincyTT's Avatar
I'm make believe
Default RE: Wierd Brake Problem
When the car sits or it rains, the rotors oxidize a little bit. when you get them warm plus the friction from the pads it goes away. Next time you dont drive it for a couple days, look for orange spots on the rotors.
That how you know if someone has been test driving a car before you buy it. If there is rust on the rotor, its been sitting for a few days.
Old Sep 13, 2007 | 06:35 PM
Member
I understand. but even if it just sits for a night it makes a horrible noise in the morning. How will I know when I need to replace my brake pads? Thanks
Old Sep 13, 2007 | 06:41 PM
auditech79's Avatar
Its fine, if you live in an area that is cold or has a lot of moisture your gonna get a little grinding in the morning, just give it one good stomp on the brakes and it should go away.
Checking the pads is easy, just flash a light in between the wheel spokes and look at how thick the brake pad thickness is, when its to about 4-5mm you should replace them, thats about the thickness of 3 nickels stacked on top of each other.
InfamousA4
Mar 11, 2009 09:39 AM
Brakisshuro
Sep 14, 2008 09:50 PM
motegiman07
Feb 19, 2008 02:10 PM
02A418T
Apr 6, 2007 07:50 AM
whartsoe789
Feb 4, 2006 04:57 PM
