will 17s ruin speed performance??
Old Nov 15, 2004 | 07:28 AM
fritz's Avatar
Default will 17s ruin speed performance??
will adding 17 inch wheels take away from the performance?
Old Nov 15, 2004 | 08:16 AM
Jestnomen's Avatar
6th Gear
Default RE: will 17s ruin speed performance??
No, my 17's have the same diameter as my factory 16's. I just have low profile tires. Actually low pro tires have better performance characteristics - less wall flex. 18 and 19" wheels might be pushing it though.
Old Nov 15, 2004 | 12:43 PM
TetrickA4's Avatar
actually having a wider tire in the back will get you more rubber on the ground and help you with turns. Also by having 17's or 18's you will have a low pro tire you tires wont roll.
Old Nov 15, 2004 | 12:58 PM
brrman's Avatar
wheel weight will hurt performance, but 17's usually mean negligible differences (or, in some instances, less weight than stock wheels)
Old Nov 15, 2004 | 03:33 PM
99a4audi's Avatar
no i would think not, depends how much they weight but even still that doesnt take away much at all. so no
Old Nov 15, 2004 | 07:17 PM
fritz's Avatar
thanks all! this site is the f*&ckin best. i used to be into the whole honda thing for about 7 years then decided to go for an audi, just the mere potential of the a4 is just amazing. ive found the right car!
Old Nov 15, 2004 | 07:23 PM
Jestnomen's Avatar
6th Gear
jeez took ya long enough!
Old Nov 15, 2004 | 07:25 PM
David_K's Avatar
ORIGINAL: TetrickA4
Having wider tires in the back? this is not a rear wheel drive car
Old Nov 15, 2004 | 07:48 PM
fritz's Avatar
how wide a tire should i get anyway? 205? 225?
Old Nov 15, 2004 | 07:49 PM
David_K's Avatar
225
