WILL THIS WORK? BT
Old Nov 25, 2006 | 07:13 PM
GODSPEED's Avatar
Default RE: WILL THIS WORK? BT
wow, I actually havnt found the Giac kit yet. Is it around the same price as the neuspeed or garrett k04 kits? I suppose i havent descided on an overall price paid or care too much about that, but as far as turbo-manifold-fuel-ecu, basically everything but exhaust and suspension-Id Ideally spend 1500-up to 2000. I wanted 12s to try and keep up with my roomates cars for a little, but even those would walk me with a 12sec car. So, I want the best bang for my buck, but I would ideally like a used kit/set-up to save a little doe and put towards some springs and rims. Any help is appreciated. Also the reason I was looking at the turbo on ebay is because I wanted to do part by part to save money and spend my money as I can instead of throwing it all in at once and then something happen where im in a bind or something.
Old Nov 25, 2006 | 07:50 PM
BaconBait's Avatar
For 12's it's going to be a lot more than $2k. Our cars are pretty heavy and it takes some grunt to get it going. You'll also need a clutch to handle the power.
Old Nov 26, 2006 | 02:24 AM
Lazer Viking's Avatar
yea..factor in about a grand for clutch soon after...300 is maxing out the factory clutch...and there is nothing wrong with buying piece by piece, but ebay isnt the best place to do that... and i think k04's are still backordered if im not mistaken
Old Nov 26, 2006 | 06:23 PM
Bondga's Avatar
This turbo is the stock turbo off of an sr20det the s15. Its from a 99-01 nissian silvia. Its specifications match thaT of a garret t28 so it shoukd fit
Old Nov 26, 2006 | 06:41 PM
BaconBait's Avatar
It will not bolt on. It has an incorrect turbine inlet and outlet.
Old Nov 26, 2006 | 07:29 PM
PandaXpress's Avatar
u need a custom made manifold for that one
the ones ATP sells the GTRS is modifide to fit on our stock manifolds thats why its so popular
Old Nov 26, 2006 | 11:55 PM
acetrebo's Avatar
Lol,
You want 12's your gonna have to put up some jack. You will probably be looking at close to 4-5k with everything.
turbo (not k04, but bigger)
new clutch
fmic
software/tuning
manifold
test pipe
injectors
intake
exhaust
FPR
Good luck trying to do a bt on a tight budget, maybe you should have chose a different car if you want to run 12's.
Old Nov 27, 2006 | 01:37 PM
  #18
GODSPEED's Avatar
I wanted 12s but i see its not in my budget. I said 2000 for the turbo/fuel i needed. Everyone here is stating 4-5grand but your talking with exhaust/fmic,all that. Ebay is the only place ive been looking for a turbo from because I cant find a used,cheaper one anywhere but there. I have sources for everything else but the turbo itself. any idea where the best place to get this k04 is? as for the BOV, I know no one else likes them here, but im putting one on my car. Just routing the air back in. And if I buy a GIAC program for my ecu, do I have to redo everything with the new turbo set-up. I assume I do but if i can i'd want to do that soon.
Old Nov 27, 2006 | 01:52 PM
  #19
acetrebo's Avatar
Why dont you just chip it and call it a day?
Are you chipped yet?
The chip willcost you about 600, you'll need a chip and DV. With this, your car will gain close to 50chp.
It will feel like a whole new car.
Then save up your money, and do the BT thing right, when you are ready.
I know this doesn't specifically answer your question, but since it sounds like you are on a budget, I would do chip,dv, exhaust, and drop in intake, and you should have quite a significant gain for about $1300. (includes cat-back exhaust).
Old Nov 27, 2006 | 02:05 PM
  #20
aRIf's Avatar
t3t4 turbo $665.
manifold for $395
@ atp
get your program from upsolute. then fuel kit there is already $2000
spend little more for wasegate, piping and some other extra stuff. get 3" test pipe for better breathing for a while. and run it low boost till you get the rest.
