<SPAN class=posttext>I noticed my A4's moon roof is a lot noisier than my VW. Has anyone else noticed this? Any cures?
<HR style="COLOR: black" align=left width="15%" SIZE=1>
</SPAN><edited><editID>GTIBlak</editID><editDate>38057.6174768519</editDate></edited>
6th Gear
I have the same problem with mine. Haven't gotten around to playing with it yet. I once read a post that you can get a door seal conditioner from the BMW dealer. Suppposidly it helps out considerably. Hope it helps, let us know if come up with anything. </P>
Apparently, the sunroof (as it's referred to in the Bentley CD) can be adjusted, though the Bentley is not clear how to do it. Specifically, the Bentley says it can be adjusted to reduce wind noise. I will have to investigate further.</P>
This is really weird because neither of my VWs ever had this problem!</P>
if anyone finds out the cure let us know - I have recently found mine give more wind noise than normal too.
I have too much else going on with the carputer and stereo install to worry about the sunroof (unless it falls out or something) heh.<edited><editID>brrman</editID><editDate>38058.4201967593</editDate></edited>
