windshield washer squirters not working
Old Jan 3, 2008 | 05:28 PM
raa4's Avatar
Default windshield washer squirters not working
The windshield washer suirters on my 04 a4 stoped working. Has anybody else have this problem?
Old Jan 3, 2008 | 05:30 PM
Sherman Banks's Avatar
Default RE: windshield washer squirters not working
Just did and fixed. Check fuse #37 and if it's blown, replace with a 30 fuse instead of the 20 that's in it.
Old Jan 3, 2008 | 05:35 PM
viper9821's Avatar
Can you hear the pump running or get someone to stand over the engine bay with the hood open and listen? I'm assuming it has fluid?
I'm not too sure about this but do the headlight washers work? Does anyone know if they use a different pump?
Old Jan 3, 2008 | 06:12 PM
At first, I thought I was out of fluid because my wipers still worked when I used the washer function, but the headlight washers wouldn't even pop up. The fuses for the wipers and the heated washer jets were still fine but I read here somewhere to check fuse #37 and to replace it with a larger one. After doingthat, it works fine. If the fuse isn't blown, you may have a bad pump.
Old Jan 3, 2008 | 10:48 PM
raa4's Avatar
I had a blown fuse and replaced it with a 30. The windshild washers work fine but the headlight washers arnt working.
Old Jan 3, 2008 | 10:51 PM
ImTheDevil's Avatar
...or for some reason the hoses that feed the sprayers may be decayed or disconnected. Check out the hoses that run from the pump to the sprayers and make sure they're not leaking. Or maybe a check valve in the system is stuck and preventing fluid flow to the sprayers.
Old Jan 4, 2008 | 04:08 AM
01A4T's Avatar
why would you want the headlight washers to work? be glad you don't have to fill up you're washer fluid every couple days......
Old Jan 4, 2008 | 12:46 PM
raa4's Avatar
Everything looks good no decayed and are not disconnected. but still dont work.
Old Jan 4, 2008 | 12:49 PM
Sorry for thedumb question, but you have your headlights on when you're trying this right?
Old Jan 4, 2008 | 01:44 PM
rsrbljan's Avatar
make sure the resivoir is filled, and headlights are on to make them work.
If the lights aren't on, they won't spray.
If the fluid is low, only the windshield nozzles spray.
FYI
