Windshield Washer system not working
Old Apr 4, 2012 | 09:10 PM
fusion28's Avatar
Default Windshield Washer system not working
Hey all,
I have a 2003 Audi A4 Avant with windshield washer system failure. I used the system a couple days ago and it worked. Yesterday it stopped working. The wipers on both front and will work, but no fluid. I thought it was just low fluid, even though I didn't get a warning, so I topped it off yesterday and tried using it with no fluid coming out onto the windshield. Today, I found a puddle of windshield wash under my car. I do not hear my pump working when I press the button and I have checked the fuses and they are fine. I bought a new pump for $15 which I will try to attach tomorrow. Any other ideas what could be wrong? Have anyone else done this on the same car?
Thanks,
Fusion
Old Apr 6, 2012 | 07:48 AM
fusion28's Avatar
***Bump***
The pump is now working. The windshields are getting fluid, the headlights are not. Read through the manual and it states that the headlights receive fluid with force from the pump. There is still leaking which are lateral of each other, so I'm thinking there's a centralized location of the leak and then the fluid travels to two different locations. Any ideas of where the central location of the hose is located? The hose is rubbed, so a the weater shouldn't make the hose crack, I'm thinking there's a plastic piece somewhere that cracked. Has anyone else had this problem?
Old Apr 9, 2012 | 03:12 PM
MKE_Audi's Avatar
The headlight sprayers are common failure points for a leak. Mine has been that way for a year and I know I can only fill the reservior half way or it will just leak out the headlight fixture. I was told eBay is a good source for replacements fairly cheap. Until you replace it, I would imagine you could just clamp the line ahead of the leak as long as there is still one fixture for the pressure to be relieved when you activate the system.
Is the puddle up front under the headlights or back by the pump?
Good time for this fix is when the front bumper is laying to the side during a timing belt service. That's what I plan to do at least.
Old Apr 10, 2012 | 04:23 AM
fusion28's Avatar
So it turned out that it was the headlight pump that was broken. After fixing that and fixing the grounding on the cable (under the steering wheel) and BAM all the sudden the headlights are getting the pressure they need to pop up. BUT, they aren't releasing and fluid. So I'm thinking a clog. Yes, there is fluid up by the headlights.
Old Apr 10, 2012 | 04:39 AM
light8008's Avatar
Banned
Originally Posted by fusion28
Hey all,
Thanks,
Fusion
you don't hear the pump, the problem may be a poor electrical connection at the pump or a bad pump.
Old Feb 26, 2013 | 02:35 PM
simplesilvera4's Avatar
Default wiper fluid not spraying
greetings. My Gfriend's A4 wiper fluid was wkg, then not. pump makes noises, no puddles generated when pump is left on for 10-20 seconds, no visible leaks (how many panels under the hood, inside the fender to find a leak!!!). I have yet to check the fuse. I hope that is it cuz the fluid barely drizzles out, and fuses are an easy fix obv. Any other clues? any help appreciated!
ps it's above freezing so I am ruling freezing out. If it's clogged, which is unlikely cuz there is a filter at the inlet port, I wonder if the nozzles can be unplugged easily.....
munichman
May 17, 2026 06:25 AM
raa4
Feb 9, 2016 07:19 PM
johnnyb123
Feb 26, 2013 03:15 PM
kacarlson65
Dec 16, 2012 06:19 PM
drewsph84
Aug 2, 2008 12:34 PM
