wiper fluid problems
Old Jan 29, 2008 | 08:12 PM
flake's Avatar
Default wiper fluid problems
Hey guys I can't figure out why my windshield washer fluid doesn't spray out? I checked the fuses and they seem to be fine. Just to clarify my windshield wipers work but no fluid comes out.
Old Jan 29, 2008 | 08:45 PM
dankhound's Avatar
Default RE: wiper fluid problems
You may want to take a look at your convienice fuse. Its like 37 or 39. Can you hear the pump run? Do the headlamp washers allso not work?
Old Jan 29, 2008 | 09:07 PM
flake's Avatar
I can't hear the pump run and the headlamp washers don't work either. I will check the convienence fuse.
Old Jan 29, 2008 | 10:49 PM
AudimaniaA4's Avatar
My windshield washer work but headligh washers dont. Is there a separate fuse for headlight washers?
Old Jan 30, 2008 | 12:14 AM
itsbigj05's Avatar
do you have washer fluid? i filled mine up, but it all leaked out after a few weeks because of those stupid headlight washers. they don't even pop up, but the pump leaks like a mother.
Old Jan 30, 2008 | 12:20 AM
dankhound's Avatar
If all the fuses check out ok youll want to get a voltmeter and check power at the pump with the switch activated. If you have power and ground you need a pump. Both pumps actually. Otherwise you will probably need a switch.
Lance Kragenbrink
Apr 23, 2010 10:42 AM
BedSores
Mar 5, 2009 10:50 AM
mbertoli
Jan 7, 2008 06:18 PM
A4Boost
Nov 10, 2007 03:19 PM
voxxtelum
Feb 18, 2007 04:08 PM
