Wipers
Old Jan 22, 2005 | 08:47 PM
slammedaudi02's Avatar
Default Wipers
So am i to assume if you have a full tank of wiper fluid, your pump is bad since it seems like everyone who has an A4 has this problem?
Old Jan 23, 2005 | 09:37 AM
david9999's Avatar
Default RE: Wipers
Could be. It could also be a clogged line. Have someone put his ear right at the fluid container when you press the switch and see if you can hear the pump. Also check the fuses.
Old Jan 23, 2005 | 08:07 PM
Jestnomen's Avatar
6th Gear
Default RE: Wipers
I would say yes, the odds of your lines becoming clogged are slim.
Old Jan 24, 2005 | 04:53 PM
Default RE: Wipers
Well I leave puddles on the snow where i park, so i guess there is a crack or leak somewhere then
Old Jan 24, 2005 | 05:38 PM
brrman's Avatar
Default RE: Wipers
yeah the seal where the pump connects to the reservoir has a reputation for going bad.
Old Jan 24, 2005 | 05:51 PM
clconversion's Avatar
Default RE: Wipers
Yes the pumps do go bad if you need a quick fix just put a fuse in and that will last you a little longer if it is just leaking out try putting in a seal first where the pump goes into the container
jowie4
B7 Models
Apr 30, 2009 12:09 PM
QuattroPhilly
Mar 14, 2009 02:19 AM
aublutiger
B7 Models
Jun 9, 2008 04:33 PM
pec2402
Jun 1, 2007 04:11 PM
Galilee
May 11, 2006 06:18 PM
