wire disconnected on engine speed sensor
can someone direct me to where i can buy the wire harness connector that connects to the engine speed sensor the black wire that connects to the connector came off and it doesnt look like i can solder it back on? thank you
You need a new sensor, the wiring is integrated with the sensor. The connector is located next to the O2 sensor connectors on the bulkhead. It should be the black connector.
its the wireing harness connecter to ecu that is damaged not the sensor portion ( the connector part that disconnectes there is three small wires a black one orange and white one you have to open up the rubber booty to access these)
