WoW! A4 gonn badddd
Old Jan 3, 2006 | 03:18 PM
dezithug's Avatar
Default WoW! A4 gonn badddd
2000 Audi A4 2.8 Quattro
Got the warning sign for what I think is a windshield washer fluid. Than I filled the whole tank with the windshield washer, turned it on went for a ride, no sign. Few minutes later came out and started the car, and there was the the sign again. Do you think it is leaking somewhere? I keep getting this sign, no matter how much fluid I put in it. Also, could there be anything else that's empty and needs to be filled? I want to have it serviced, how much am I looking at? Thanks.
Old Jan 3, 2006 | 03:32 PM
The A4 Man's Avatar
Default RE: WoW! A4 gonn badddd
mine does the same thing its really annoying...I have a 2000 too. IDK how to fix it.
Old Jan 3, 2006 | 03:39 PM
sandman's Avatar
you need to find where the leak is coming from. the common place is between hoses where that plastic clip is. if you pull out the lower grill on the drivers side you will be able to see this hose connection. fill up the resevoir and see if the leak comes out of there, if it does thats the problem, buy a new clip, or inspect the o rings between the connection.
Old Jan 3, 2006 | 04:25 PM
dezithug's Avatar
How much do you think Audi dealers will charge for this?
Old Jan 3, 2006 | 06:02 PM
18T's Avatar
18T
mine does that like 2 times a month its annyoing. i think i have a leak also.
Old Jan 3, 2006 | 07:27 PM
flyboy's Avatar
ORIGINAL: dezithug
how many arms and legs you got laying around, you might want to bring them if you take it to the dealer.
Old Jan 3, 2006 | 07:33 PM
98 A4 Turbo's Avatar
ORIGINAL: flyboy
ORIGINAL: dezithug
haha he's got a good point... find a shop that specializes in german cars. a dealership will tell u that the entire assembly needs replacement instead of just the clip or o-ring.
Old Jan 3, 2006 | 07:52 PM
turbo's Avatar
Check the O rings on head light washers thats where my leak was.
Old Jan 3, 2006 | 08:35 PM
audiboy1618's Avatar
When you fill it up, and then its gone without you using it, alot of times that means theres a leak
Old Jan 3, 2006 | 10:31 PM
Karl's Avatar
ORIGINAL: audiboy1618
damn you beat me to it..
