WTF
Old Oct 27, 2005 | 04:48 AM
///A4's Avatar
Default WTF
ok i have a 97 1.8t quattro and in the dash there are four lights that can come on btw the gauges. the gas one and 3 other ones but this one light keeps comin on wenever i turn or brake. its red and looks a like a thermometer. but im not sure wut is and i dont' have a manual.
pls tell me ASAP
Old Oct 27, 2005 | 04:54 AM
///A4's Avatar
Default RE: WTF
Old Oct 27, 2005 | 04:58 AM
russianari's Avatar
Default RE: WTF
maybe its your coolant level, your car might be just a little low and when you turn or slow down the sensor picks up that its low.
Old Oct 27, 2005 | 05:01 AM
///A4's Avatar
Default RE: WTF
and how do i solve this problem?
Old Oct 27, 2005 | 05:02 AM
///A4's Avatar
Default RE: WTF
can there b a leak? and how much would it b to fix if its leaking
Old Oct 27, 2005 | 05:04 AM
///A4's Avatar
Default RE: WTF
Old Oct 27, 2005 | 05:15 AM
russianari's Avatar
Default RE: WTF
1.open hood
2. look inside
3. locate coolant / antifreeze reseviour container.
4. look at the level
5. if low follow these insturctions:
a. dont panic
b. look at the cap does it say something like g12+ and what color is it, green or pinkish orangish
c. if green get antifreeze if pinkish orange go to audi or vw and get antifreeze
d. fill to proper level
6. if it will leak out, i would assume that you would notice white smoke and a sweet smell from your exhaust or a puddle on the ground, see where its leaking from, a hose is a few dollars, a clamp is like 50 cents and a radiator is like $200 to $500, a cracked block is a lot. it is doubtful that its a cracked block or radiator, and its not unusual to be low on antifreeze on occasion.
good luck
Old Oct 27, 2005 | 05:16 AM
///A4's Avatar
Default RE: WTF
**** something is leakin in the back of my engine. it's dried up and its like yellowish white. WTF is this!?
Old Oct 27, 2005 | 05:18 AM
russianari's Avatar
Default RE: WTF
it might be antifreeze, maybe a new gasket... go to a mechanic if it keeps on leaking
Old Oct 27, 2005 | 05:27 AM
///A4's Avatar
Default RE: WTF
its leaking where the hose is connected to the engine and it blinks more often. worst comes to worst what is the worst thing that could happen? and how muc would it b
