WTF......Please Help
Old Nov 1, 2006 | 11:40 PM
fher7096's Avatar
Default WTF......Please Help
Just out driving normal and all of a sudden car looses power and stars studdering and check engine light is flashing. Pulled over and checked oil-OK. Turbo is glowing. Exhaust is studdering like I am on 2-3 cylinders. 3 weeks ago I changed the spark plugs with OE plugs. I am going to get my friends diagnostics tool. I will post the codes.
Old Nov 1, 2006 | 11:42 PM
twiggy114's Avatar
Default RE: WTF......Please Help
hey kinda like what my car is doing but i did not get a CEL. Still going to get it pluged and find out whats going on.
Old Nov 2, 2006 | 12:05 AM
fher7096's Avatar
Code read P0302 cylinder #2 misfire. I erased the code started it back up and same s#$%. I think it may be one of the new plugs being defectice. Any other ideas from anyone???
Old Nov 2, 2006 | 12:33 AM
chaos92287's Avatar
most likely ICM
Old Nov 2, 2006 | 12:39 AM
fher7096's Avatar
Any way to check the ICM. And what is the ICM?? Thanks again.
Old Nov 2, 2006 | 12:56 AM
chaos92287's Avatar
ignition control module...but i just noticed you had a b6 and i dont know if they have them cuz DBW cars dont have them. if you do its on top of the stock airbox
Old Nov 2, 2006 | 01:03 AM
dankhound's Avatar
Its probably a bad coil. Swap the coil to another cylinder and see if the misfire follows the coil.
Old Nov 2, 2006 | 01:10 AM
keko2004's Avatar
its the icm. listen to chaos. i had the same exact problem ur describing. dont buy the oem one either, get the german one. just as good.
Old Nov 2, 2006 | 09:53 AM
fher7096's Avatar
switched plugs got same coils then switched coils and got 0303 cylinder 3 misfire so I take it the coil is shot. Who offers some better coils?
Old Nov 2, 2006 | 10:05 AM
dafrazi's Avatar
There is no ICM on the '02.
