xenon 6000k in fog lights
Old Dec 14, 2004 | 11:54 AM
alejandrorodrigu's Avatar
Default xenon 6000k in fog lights
i put the aftermarket xenon upgrade in the fog lights, but the computer don´t recognize the xenon system, and the signal appears (don´t have fog lights !), then when i turn on the switch of the fog lights some times the fog lights turn on, and some times not, how can i fix this problem, any idea?
Old Dec 14, 2004 | 01:21 PM
CRAZYHAWK's Avatar
Default RE: xenon 6000k in fog lights
The new bulbs may have different resistance , confusing the computer. Are you using ballasts with the fog lights? In the past fog lights were usually amber not blue ,6K.
Old Dec 14, 2004 | 03:51 PM
yes i am using ballast, maibe can it be the fuse
Old Dec 14, 2004 | 06:38 PM
CRAZYHAWK's Avatar
It's not the fuse. If afuse blows it will never work.
Old Dec 16, 2004 | 03:32 AM
04a4's Avatar
you need 15 or 30amp fuses (don't remember right now, i will in the morn...) in order for HID's to work....
Old Dec 16, 2004 | 03:44 AM
sfordeso's Avatar
15. but crazyhawk is right. if it was the fuse, they wouldn't come on at all
Old Dec 16, 2004 | 01:34 PM
i don´t think that the fuse make it turn on or off the lights some times, i just think that the amp of the fuse maibe confuse the ecu and that is why the computer sometimes it send the message (fog lights failure)
Old Dec 16, 2004 | 03:32 PM
sfordeso's Avatar
it sounds to me like a faulty connection. could be anywhere.
Old Dec 16, 2004 | 03:33 PM
CRAZYHAWK's Avatar
Either fuse has near zero resistance. As I said before , the resistance of the ballast , xenon combination might be different from the origonal bulbs.
Old Dec 16, 2004 | 10:47 PM
did you have any idea to fix this problem ? can some body help me? a frend put the same upgrade in his b5, look the pics:
[IMG]local://upfiles/3506/5BA50CF2CFFA4ADBAFCE5F773E4333F5.jpg[/IMG]
[IMG]local://upfiles/3506/ECB14B31544843FBBDB342A81FA2F955.jpg[/IMG]
